I’m having some problems on my audi a1 tdi 1.6 with my lights. Some lights don’t work but some do, I’ve changed the bulbs and attempted to change the fuse but it still doesn’t work anyone had this problem
Sorry to ask for more detail Ellie, but which ones work and which don’t?
If you've replaced the bulbs then I'd recommend you get an auto electrican to take a look
Thanks Ellie,
My normal first port of call is to eliminate any fractured wires within the flexible harness section into the tailgate/boot, but I feel your car isn’t generally oiled enough to suffer with this problem at this time. Worth an elimination though -??
Do you have a multi meter,  and are you handy with it?
If not, then I too would suggest you leave this in the hands of a trusted local auto electrician.
  • 4 months later...
know fact a lot of a1 get burnt plastic on the connection in boot on the rear lights
i have changed the wiring twice on a girl at work as it keeps melting the rear cluster
Robotic girl James?
Sorry, couldn’t resist that.
her one , always seems to go a few weeks before the mot, so havent losted long at all,
she is now looking into changing the car, as been done 3 times
