Hi Guys ,I may be picking up old subject so apologies if that's the case . I've recently caused some drivers side damage to my Audi A4 2013 S line quattro Avant and I'm having a headache sourcing right parts for replacement.
I am needing new drivers and drivers side passenger door and front wing . I'm not sure if you can take both from similar year /shape A4 and they would fit or should they be from an Avant only ? Also, I assume my model is B8 ? Same with front wings - does being s line make any difference to this ?
Thanks so much in advance. There isn't many Misano red A4 parts around and wouldn't want to order wrong doors that would not fit .
Yep you'll need Avant doors as the tops of the doors are different.
S line bumpers are different but think wings are the same.
Steve Q , thanks for the response. I've been seeing confusing posts saying that the front door may fit ,but not the back 🤯
Would doors from Avant from a different year fit ? I see many people listing 2008 to 2015 as same fitment 🤯
If you're referring to saloon then front door might fit. But definitely not rear. It's the top of the door frame which is the issue. As the saloon and Avant have different roof lines.
  • Thanks 1
That makes a lot of sense . Thanks mate
Any ideas regards fitment from older /newer models ?
