Azharul Posted September 13, 2023 Posted September 13, 2023 Hi Guys Having few issues with my Audi A6 C7 16 plate, have multiple fault codes coming up on my dashboard all at once. Not sure why this is as it is the first time this is happening to my car. The car is currently underivable as power is not going through. I believe it’s an electrical problem but not sure from where. faults codes are TPMS, Gear box malfunction, steering wheel, parking brake Etc. Any help would be appreciated! thanks!
alpha omega Posted September 13, 2023 Posted September 13, 2023 when you get multiple faults our friend steveQ has mentioned possible battery thats causing these issues 1
a6blacked007 Posted September 20, 2023 Posted September 20, 2023 Has this was abs sensor passenger front
Azharul Posted September 20, 2023 Author Posted September 20, 2023 Have you got a number I can contact you on to discuss it further with you about this abs sensor? 1
Magnet Posted September 20, 2023 Posted September 20, 2023 Hello Azharul, Giving direct contact details of forum members on an open forum must obviously be discouraged. You can contact Mark via. the message system on here.
a6blacked007 Posted September 21, 2023 Posted September 21, 2023 8 hours ago, Azharul said: Have you got a number I can contact you on to discuss it further with you about this abs sensor? Err no You will need it scanned with odis. Your fault could be different to mine, There are many posts on here regarding your fault. Regards mark 1
DavidMcP Posted February 9, 2024 Posted February 9, 2024 Hi Azharul, I am having the same problem with my A6 Allroad 2016, how did you sort yours
DavidMcP Posted February 9, 2024 Posted February 9, 2024 On 9/20/2023 at 9:56 PM, Azharul said: Have you got a number I can contact you on to discuss it further with you about this abs sensor? Hi There, I am having the same problem with my A6 Allroad, how did you sort your problem?
Magnet Posted February 9, 2024 Posted February 9, 2024 Hello David, Azharul never returned to the forum since he was advised that he couldn’t have access to Mark’s phone number. I would suggest you send him a PM, and hopefully he may reply. Back to your issue:- under any circumstances where you have multiple warning lights illuminated, my first port of call is to eliminate the battery as being an offender - on the basis of carrying out free/low cost assessments first. Halfords (shops) should be able to do that while you wait. If found to be substandard, it would be to your advantage to let the forum know before buying one. Perhaps you could let us know how you get on. Kind regards, Gareth.
DavidMcP Posted February 9, 2024 Posted February 9, 2024 4 minutes ago, Magnet said: Hello David, Azharul never returned to the forum since he was advised that he couldn’t have access to Mark’s phone number. I would suggest you send him a PM, and hopefully he may reply. Back to your issue:- under any circumstances where you have multiple warning lights illuminated, my first port of call is to eliminate the battery as being an offender - on the basis of carrying out free/low cost assessments first. Halfords (shops) should be able to do that while you wait. If found to be substandard, it would be to your advantage to let the forum know before buying one. Perhaps you could let us know how you get on. Kind regards, Gareth. Thanks Gareth, ill try that and get back to you
