Hi Guys
Having few issues with my Audi A6 C7 16 plate, have multiple fault codes coming up on my dashboard all at once. Not sure why this is as it is the first time this is happening to my car. The car is currently underivable as power is not going through. I believe it’s an electrical problem but not sure from where.
faults codes are
TPMS, Gear box malfunction, steering wheel, parking brake Etc.
Any help would be appreciated!
thanks!
when you get multiple faults our friend steveQ has mentioned possible battery thats causing these issues
Have you got a number I can contact you on to discuss it further with you about this abs sensor?
  • Haha 1
Hello Azharul,
Giving direct contact details of forum members on an open forum must obviously be discouraged.
You can contact Mark via. the message system on here.
Err no
You will need it scanned with odis. Your fault could be different to mine,
There are many posts on here regarding your fault.
Regards mark
  • 4 months later...
Hi Azharul, I am having the same problem with my A6 Allroad 2016, how did you sort yours
Hi There, I am having the same problem with my A6 Allroad, how did you sort your problem?
Hello David,
Azharul never returned to the forum since he was advised that he couldn’t have access to Mark’s phone number.
I would suggest you send him a PM, and hopefully he may reply.
Back to your issue:- under any circumstances where you have multiple warning lights illuminated, my first port of call is to eliminate the battery as being an offender - on the basis of carrying out free/low cost assessments first.
Halfords (shops) should be able to do that while you wait. If found to be substandard, it would be to your advantage to let the forum know before buying one.
4 minutes ago, Magnet said:
Hello David,
Thanks Gareth, ill try that and get back to you
