Hello, friday morning I has these errors all come on at the same time whilst starting up. I just wanted to check if they're all likely to be related to each other/a fault with the ABS sensor?
Ive seen a few posts about the ABS and stop start being related but i dont see how the headlight range control could be?
It looks like a pretty cheap/easy part to replace if thats what is causing the issues. Or is there anything else i should check first?
Many thanks in advance
Hello Paul,
I think you will find that such issues could be linked to an inefficient battery, so my first port of call would be to eliminate or confirm that possibility.
I would take the car for a 15 to 20 mile run, then get the battery efficiency check - Halfords can do this.
Buying a necessary replacement from Halfords- ?
I’d hope not it’s only a year old and supplied by my local Audi specialist. But thanks Ill do that first thing in the morning
Thanks Paul,
Even if it does turn out to be sub-standard, then it should be under warranty. If it’s serviceable then obviously you have at least eliminated it. What make is the battery by the way?
Worth getting Halfords to do an alternator test at the same time.
Can’t/ don’t want to download your link.
Alternator output checked?
I wouldn’t have thought an ABS fault would knock off the Stop/start, but I guess stranger bits of Audi logic have occurred.
Your car is probably too old to have the additional ‘small battery’ as well as the main battery -?
When a series of apparently unrelated electrical faults appear simultaneously my first suspect is always the battery. It does not matter if the static voltage is fine, it does not matter if the starter can crank the engine over normally, it can still have a fault that interferes with the car's electronics.
Sorry, but too I will not download links from unknown sources. Can you attach the file to a reply?
Here’s a list of trouble codes I’d that helps
03841 - RPM Sensor Rear Left: Incorrect Signal.
00290 - ABS Wheel Speed Sensor Rear Left (G46)
01316 - ABS Control Module
below is directly copied from carista. After googling some of these seem to be displaying incorrectly I believe…
CAN network gateway:
01304 - Radio
ABS:
00290 - Left rear ABS wheel speed sensor
03841 - Hybrid/high-voltage battery group 2: Performance
Power steering:
01316 - Engine Oil Pressure Too Low
Steering wheel:
01304 - Radio
Telephone:
01304 - Radio
02503 - Output wire to radio
Headlight aiming:
Heater & air conditionina
01592 - Throttle Actuator control (bank1)
Range/Performance
Hi, I am having the same issues as well on my Audi A6, incorrect fault codes have been coming up. I assume it will be the battery as I am getting mine changed on Wednesday
Hello Azharul,
I wouldn’t assume anything. You could find it isn’t the battery after you have unnecessarily spent money.
I would simply get it tested and depend on the result to inform you it is/isn’t serviceable.
Heel Paul,
‘Alternator seems to be fine’. Have you actually had its output checked?
Hello Mganet,
I got my battery tested yesterday RAC they said it serviceable/rechargeable, the Votage it is currently at is 12.47. They said this is too low. They tested the alternator out as well, reported back saying all is fine with the alternator.
Expand
Please let us know the outcome as Paul seems reluctant to accept any suspicions regarding his battery.
Battery voltage is 12.6v with engine off and 14.2 with engine on. No blown fuses either.
It'll be in the garage Thursday so we’ll find out what’s the crack
Been in to the garage and all these faults were caused by a faulty ABS sensor at the rear it was given false readings compared to the rest
  • 10 months later...
Posted (edited)
Hi,
my Audi A3 has had all of the same faults appear at once when I started my car today. Please could you let me know how you managed to resolve this? Thanks
Edited by Charlotte foth
Welcome Charlotte, and thanks for joining.
Back in Oct. 2023, Paul outlined what the offending part was on his ( in caps)  car.
Could  you please outline the exact issues you are getting with your car.
To save asking again, how old is your battery?
