WATER FALLING FROM ROOF
Go to solution Solved by Steve Q,
I’ve recently changed my car for a 2023 A6. I have had several A6’s in the past and never had this issue before.
When it rains (or has been raining) and I get into the car and close the door a load of rain water falls in on top of my arm/ leg (destroyed) and also falls on the electric switches on the door.
Has anyone experienced this before?
  • Solution
Not heard of any other cases. As it's a new car I'd recommend for you to get it checked by Audi.  As it could be a faulty seal or nis-aligned door.
  • Thanks 1
Only if the window is open or when opening the door I’ve parked on a slope and on opening the door the water pools at the edges.
Can’t say I’ve had that.
Now water falling in the boot when it’s opened after rainfall…
Expand
My 2021 S6 Avant collects water in the tailgate and then has a waterfall each side the boot is opened. I am not sure if the roof spoiler fills or if it is the small blades either side.
Basically it is more !Removed! design on a car that is a big pile of !Removed!, all the journos who reviewed the car and said it is wonderful should hand their cards in.
