harry71 Posted September 20, 2023 Posted September 20, 2023 Hi all, Had issue with handbrake sticking for a while and the other day it triggered a few lights. Start/stop fault Abs fault Cruise control fault Traction control fault Parking sensor fault Headlight fault. All abit strange, anyone had anything similar? Dont fancy sending it Audi and they replace everything when maybe it might just be one of the above. Cheers
Magnet Posted September 20, 2023 Posted September 20, 2023 Thanks Harry, Have you searched various threads where multiple warnings show up? Kind regards, Gareth.
harry71 Posted September 20, 2023 Author Posted September 20, 2023 On 9/20/2023 at 12:35 PM, Magnet said: Thanks Harry, Have you searched various threads where multiple warnings show up? Kind regards, Gareth. Expand Thanks for reply Gareth, No i only just joined the forum, wasn't 100% how it all worked so thought I'd try my luck posting this
Magnet Posted September 20, 2023 Posted September 20, 2023 Thanks Harry, Worth a topic search under ‘ Multiple warning lights’ or similar. First thing to check would be the battery efficiency - Halfords should be able to do that for you. Perhaps you could let us know how you get on. Kind regards, Gareth.
harry71 Posted September 21, 2023 Author Posted September 21, 2023 On 9/20/2023 at 9:30 PM, Magnet said: Thanks Harry, Worth a topic search under ‘ Multiple warning lights’ or similar. First thing to check would be the battery efficiency - Halfords should be able to do that for you. Perhaps you could let us know how you get on. Kind regards, Gareth. Expand Cheers mate, will keep you posted
harry71 Posted September 21, 2023 Author Posted September 21, 2023 On 9/21/2023 at 12:12 PM, harry71 said: Cheers mate, will keep you posted Expand Battery is very weak so they say. Looking at 180 for new one
Magnet Posted September 21, 2023 Posted September 21, 2023 Well there’s the likely answer to your problem then Harry. £180 for a replacement battery? Tip (1) :- Type you registration number into on-line battery specialist suppliers such as Tayna or Battery Megastore ( there are others). They will list a number of alternative makes at varying prices. Tip (2) :- Buy good quality at competitive prices. I never buy cheap batteries, but buy premium brands and grades at most competitive prices. Beware, even top grades such as Varta/Bosch, Exide etc. have differing grades of the same battery type within their range. I alway buy with at least a 4 year warranty grade. Have been using Varta/Bosch, but bought an Exide (Premium, not Excel-important) and impressed so far. The supplier will suggest you check the battery dimensions, its capacity in terms of Ah, and it’s Cold Cranking current (CCA) against your current one. Perhaps you could let us know how much you will save via. this route Harry. Kind regards, Gareth.
harry71 Posted September 26, 2023 Author Posted September 26, 2023 On 9/21/2023 at 2:18 PM, Magnet said: Well there’s the likely answer to your problem then Harry. £180 for a replacement battery? Tip (1) :- Type you registration number into on-line battery specialist suppliers such as Tayna or Battery Megastore ( there are others). They will list a number of alternative makes at varying prices. Tip (2) :- Buy good quality at competitive prices. I never buy cheap batteries, but buy premium brands and grades at most competitive prices. Beware, even top grades such as Varta/Bosch, Exide etc. have differing grades of the same battery type within their range. I alway buy with at least a 4 year warranty grade. Have been using Varta/Bosch, but bought an Exide (Premium, not Excel-important) and impressed so far. The supplier will suggest you check the battery dimensions, its capacity in terms of Ah, and it’s Cold Cranking current (CCA) against your current one. Perhaps you could let us know how much you will save via. this route Harry. Kind regards, Gareth. Expand Hey mate. Just a update, took it into Audi and whats causing it all is the abs pump. All wires etc were fine. Its either buy a new one (£1500) or send it off and hopefully get it repaired. I looked into second hand ones which were alot cheaper but Audi have said it will be more costly buying second hand one and having the pain of trying to get it coded in.
Magnet Posted September 27, 2023 Posted September 27, 2023 What happened about renewing the known-to-be-inefficient battery Harry? Kind regards, Gareth.
