Got an audi a4 b7 2.0 tdi 6 speed manual does anyone know which mount i need thanks
Seen some transmission mounts on eBay but the y bracket look different can i take the rubber mount part off and put it on my original y bracket
6 hours ago, Beany1 said:
Seen some transmission mounts on ebay but the y bracket look different can i take the rubber mount part off and put it on my original y bracket
Hi try buying the right part using your VIN/REG NO. then it will fit swapping bonded rubber parts is a disaster in the making.
Hi thanks stevey i put in reg no and it comes up with this mount but my y bracket is slightly different so im thinking i can swap out the rubber mount and use it on my original y bracket because the rubber looks the same
