Hi all,
New member here - hello!
I’ve got a 2012 A6 C7 Avant, which is brilliant. However, every now and then I could do with a little extra road clearance. I’m toying with the idea of selling it and getting an Allroad, but then I came across these:
https://www.ebay.co.uk/itm/313672413223?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=3tCt0looTnq&sssrc=4429486&ssuid=GjpWGa-CQRa&var=&widget_ver=artemis&media=WHATS_APP
They look similar to these - https://www.forgemotorsportoverland.com/products/audi-porsche-lift-kits-a4-a5-a6-allroad-a7-q6-and-macan
Has anyone fitted anything like this? If so, did you encounter any issues afterwards? A more mechanically minded friend suggested it might work but the camber of the tyres and also the driveshaft would have to be checked.
Cheers,
Tom
Edit: it’s an S-Line, if that makes a difference!
Hi don't bother with the expensive gizmos as it will only make the handling wayward, invest in a set of standard Avant springs as I believe the S Line is 25-30mm lowered from the factory, you will have to get it re aligned on a HUNTER four wheel tracking machine, change the front and rear springs otherwise it will dive at the front when braking.
  • Thanks 1
