gavin1984 Posted October 2, 2023 Posted October 2, 2023 Hi guys, cars started to make bit of a noise, I'm no mechanic but I've got a suspicion it's the flywheel "really hoping it's not" makes the noise when idle in neutral but when clutch is engaged no noise. Have attached small video clips. Any help would be appreciated. Thanks.聽 PXL_20231002_085500038.TS.mp4
Stevey Y Posted October 2, 2023 Posted October 2, 2023 9 hours ago, gavin1984 said: Hi guys, cars started to make bit of a noise, I'm no mechanic but I've got a suspicion it's the flywheel "really hoping it's not" makes the noise when idle in neutral but when clutch is engaged no noise. Have attached small video clips. Any help would be appreciated. Thanks.聽 PXL_20231002_085500038.TS.mp4 Hi sounds very much flywheel, it goes quite when you push the clutch in because that takes up the slack in the flywheel. Steve. 1
gavin1984 Posted October 6, 2023 Author Posted October 6, 2023 Thanks for the reply buddy, i feared it might be 馃槶 noise is the same but after a long drive clutch is starting to ride a bit聽 1
