cosmaa1 Posted October 8, 2023 Posted October 8, 2023 I have a 2012 A4 B8. I had a loose intake manifold bolt that would not tighten. I removed the intake manifold and installed the heli coil. Now the car will not start. Just turns over and a gas smell. The car ran great before I removed the manifold. I don’t think I forgot any connectors. Any suggestions? If somehow there is a connector problem, can someone identify which one to check that may cause this issue. Thanks TC
alpha omega Posted October 9, 2023 Posted October 9, 2023 my friend from england uk had a friend that lived in chesepeake west virginia lovely place.sorry i cant help with your question hope someone comes along soon
Steve Q Posted October 10, 2023 Posted October 10, 2023 I'd recommend a diagnostic check to see if any fault codes flag up
andrew1267 Posted March 18, 2024 Posted March 18, 2024 Have a good look around the intake manifold to check if you have trapped a wire maybe the wires for the crank or cam sensor or something else that could be shorted to ground
