I bought myself 2003 Audi A3 8P a few months ago, and since then, my ESP light on the cluster has been staying a bit illuminated. Anyone know what the issue might be? Can it be a blown bulb?
Hello Kristiyan,
Welcome to the forum.
One thing it wouldn’t be is a blown bulb - it wouldn’t illuminate at all.
This could be a weak signal from one of the ABS wheel sensors or senders, but regrettably you will need to have the car diagnostically checked to give you a good indication where the fault lies.
  • Solution
Posted (edited)
7 hours ago, Magnet said:
Hello Kristiyan,
I got it checked via VCDS and got a steering angle sensor fault. And that I needed to do a system function test to remove the fault.
Edited by kris69420
