Hi all
I have an A3 sport ,after driving through flood having problems with lights
o/s headlight dipped and full beam no plate lights o/s fog light o/sfront indicator rear n/s indicator not working
bulbs appear ok any suggestions what problem could be
The problem is obvious: there is water in one or more parts of the electrical system. Water and electricity do not mix.
The solution is altogether less easy. Every single electrical connection in and around every single light needs to be opened, cleaned, and dried. That includes any plug connections on the wiring loom. If should go without saying that any water inside the light fittings also needs to be drained to ensure the problem does not reoccur.
