Hi guys. The rear parking sensors on my Audi A6 C7 have stopped working, and instead i just get a permanent beep sound whenever I put it in reverse. The parking sensor light inside the vehicle also flashes (instead of a permanent light) when this happens. I imagine it might just be a loose connection somewhere, any ideas? Or how I check the connections? Thanks.
Hello Dan,
Welcome, and thanks for joining.
‘loose connection somewhere…’ - if only.
More likely to be one of the sensors is defective. Question is which one -? Some say you can detect which one by selecting reverse and putting your ear to each one in turn, and there should be a different tone. Does that work in practice?? Worth a try.
It has also been said that a squirt of WD40 sometimes fixes the offending sensor. Will that work for you?
If neither of these work, then it’s likely to be a case of getting it plugged in to find which of the sensors is defective. They may not all be the same across the car ( often different crank angles on the connector section) , so ask for the part number
Once you have found the offender, Audi will want to extract probably north of £120/ sensor from your wallet.
Alternative:-have a look on eBay for the same part number, and buy one for less than £20 ( colour coded if you pay a bit extra). You might find it will come with the same Audi part number actually embossed on it - clever!
Fitting:- some can be difficult to get at, and pessimistic situation is the bumper may have to be removed.
Alternative issue ( but less likely) is that the actual module is at fault, but that would be much rarer.
Perhaps you could let us know how you get on Dan.
