Rob57 Posted November 25, 2023 Posted November 25, 2023 Hi, My avant has just illuminated the glow plug light (flashing on/off). My scanner suggests it is a fault with the brake light switch/circuit. The brake lights are on all the time (ignition switched on) and with switch disconnected. Any known wiring fault suggestions would be grateful. Also looking for a wiring diagram. Â Thanks
Steve Q Posted November 25, 2023 Posted November 25, 2023 I'd definitely recommend changing the switch.Â
Solution Rob57 Posted November 28, 2023 Author Solution Posted November 28, 2023 On 11/25/2023 at 6:21 PM, Steve Q said: I'd definitely recommend changing the switch. Replaced the switch today, cleared fault codes and all good. Switch must fail safe and put lights on? Cheers
Steve Q Posted December 2, 2023 Posted December 2, 2023 On 11/28/2023 at 2:03 PM, Rob57 said: Replaced the switch today, cleared fault codes and all good. Switch must fail safe and put lights on? Cheers You're welcome, glad you got sorted 🙂
