Mmcfly Posted November 27, 2023 Posted November 27, 2023 I'm hoping for some help with the wife's 2015 Audi A3, she bought it this weekend and on the way back it started going into limp mode and showing P2002 codes. Now we were meant to pick it up weekend before last but the dealer had that code come up. Apparently he took it to the garage and they changed the egr cooler, reset the code and though the job was done. The garage also said that the dpf was not blocked and all was ok. I've take it for a drive, after resetting the code and almost immediately P2002 (pending) shows, when driving slow around town the car seems fine except for the pending code. When driven hard, or at high revs low gear down the motorway the car really kicks off and shows a flashing glow-plug light. To me it seems the trouble really starts the more gas you're pushing through the system which would indicate a blockage to me. I guess the question is since its had its egr cooler replaced, what else could it be? One other thing that is puzzling, is that I've seen the invoice for the egr cooler and it came to a little over £400 fitted, which seems a little cheap to me? We can take the car back no problem, but its a 4 hour drive and the logistics would be a nightmare.
jdragon Posted November 28, 2023 Posted November 28, 2023 What's the engine code? There's a pressure sensor that's part of the EGR system which will give the same error code if faulty at ~£90 I'd enquire with the dealer to find a way forward with a local repair.
Mmcfly Posted November 28, 2023 Author Posted November 28, 2023 6 minutes ago, jdragon said: What's the engine code? There's a pressure sensor that's part of the EGR system which will give the same error code if faulty at ~£90 I'd enquire with the dealer to find a way forward with a local repair. Thanks for the reply bud, I've not got my hands on any decent software for the car yet, the only code I've got is a generic obd p2002. The dealer seems like he is pushing for a return as he's worrying it will be a never ending pit of money I guess. Ive got it booked in tomorrow with a dpf specialist, fingers crossed with the right gear he can see if the sensors are OK?
Mmcfly Posted November 28, 2023 Author Posted November 28, 2023 4 hours ago, jdragon said: How many miles has the car done? 115k 2015 1.6 tdi sport bud, it would be a shame to have to take it back as it's in really good condition.
jdragon Posted November 28, 2023 Posted November 28, 2023 I very much doubt it's the DPF. That code is for the EGR cooler. I documented my progress on this in the A5 section. Let us know how you get on.
Mmcfly Posted November 28, 2023 Author Posted November 28, 2023 1 hour ago, jdragon said: I very much doubt it's the DPF. That code is for the EGR cooler. I documented my progress on this in the A5 section. Let us know how you get on. That's the strange thing, it had a new egr cooler last week. Managed to get a dpf specialist to look at it and all the live data tomorrow, hoping it's just a sensor or something.
Mmcfly Posted November 29, 2023 Author Posted November 29, 2023 11 hours ago, jdragon said: Did it though....... Yh we've got the invoice stating it, was quite cheap @430 all in. definitely an aftermarket part.
Mmcfly Posted November 29, 2023 Author Posted November 29, 2023 15 hours ago, jdragon said: Did it though....... Just got back from the live data guy, said a dpf pressure sensor was too high and the DPF had a lot of soot. Was going to buy a sensor on the way back but it looks like there are two so I'll have to look into it. Got some pics from it though.
Mmcfly Posted November 30, 2023 Author Posted November 30, 2023 So apparently, this cars pressure sensors are slightly different, but even Audi are saying they don't know exactly which one is which. The have a diagram where two are showing and the exploded view (with a difference in part number is shown) only show's one. Looks like I will have to buy both and play around with them. Anyone come across these different part numbers before, and could a miss-match cause problems?
jdragon Posted November 30, 2023 Posted November 30, 2023 This is the sensor I was referring to, but I can't remember which one it is. If I recall, it's very conveniently located on the top of the engine. There's a thread on the topic (possibly on here or VWAudi forum) that has the info needed.
Mmcfly Posted December 2, 2023 Author Posted December 2, 2023 (edited) On 11/30/2023 at 7:50 PM, jdragon said: This is the sensor I was referring to, but I can't remember which one it is. If I recall, it's very conveniently located on the top of the engine. There's a thread on the topic (possibly on here or VWAudi forum) that has the info needed. Thanks buddy, replaced a sensor (left hand - pre dpf) with a cheap 20 quid knock off (next day amazon) but still threw a code, might be frowned up but I flushed through a 1000ml of partially diluted (RO water) Dawn oven cleaner through the dpf via left hand side pressure regulator pipe with engine running as I didn't want backwash into the cylinders. Used one of those cheap hand pump garden sprays and MacGyver jerry-rigged tubes. Lots of smoke came out the back >< anyway, dpf pressure went down loads (4mbars when it was 16mbars) swapped the sensors round, told the car I had just replaced the dpf and to train the sensors via a Launch CRP129x (bought for this job) Long story short- did a 100mile round trip on the motorway and it didn't throw any codes so I presume it' can regen now. I'm fairly certain the garage swapped the egr cooler when it was the sensor at fault, and it had been driven for quite some time leading to the dpf being blocked, a combo of new (egr side) differential sensor and a really harsh dpf clean sorted the problem out. Thanks for your help bud 🙂 Edited December 2, 2023 by Mmcfly hello 1
jdragon Posted December 3, 2023 Posted December 3, 2023 Great news you've got this sorted. What is the part number for the sensor? Do you have a photo of it's location? It would be really helpful should anyone else have the same issue. 2
Mmcfly Posted December 3, 2023 Author Posted December 3, 2023 (edited) 13 hours ago, jdragon said: Great news you've got this sorted. What is the part number for the sensor? Do you have a photo of it's location? It would be really helpful should anyone else have the same issue. Picture shows two sensors, left one is a pre DPF pressure regulator and the pipe seen is the one that is used to put cleaning fluids in, unless you really know what you're doing only push cleaning fluid through with the engine running as if you put too much in when engine is off there is a risk of fluid going into the cylinders and causing a hydro-lock. If you really want to put loads of fluid in when engine is off and to let it soak, maybe put fluid in directly though the o2 sensor holes, you'll have to remove glow-plugs to expel any liquid out of cylinders. Right one is post DPF and EGR sensor (as far as I can tell) This is the one that was faulty, I used a cheap knock off from amazon for 20 quid (03L906051B) which is slightly different as the one on the car originally (04L906051B) and that was used on the left hand side, then I replaced the one on the right with the original I had just taken off. No idea if the slight difference means anything, though I am going to fit an OE part tomorrow at a cost of around £100. Edited December 3, 2023 by Mmcfly 1
simlocks Posted February 2 Posted February 2 On 12/3/2023 at 8:52 PM, Mmcfly said: Picture shows two sensors, left one is a pre DPF pressure regulator and the pipe seen is the one that is used to put cleaning fluids in, unless you really know what you're doing only push cleaning fluid through with the engine running as if you put too much in when engine is off there is a risk of fluid going into the cylinders and causing a hydro-lock. If you really want to put loads of fluid in when engine is off and to let it soak, maybe put fluid in directly though the o2 sensor holes, you'll have to remove glow-plugs to expel any liquid out of cylinders. Right one is post DPF and EGR sensor (as far as I can tell) This is the one that was faulty, I used a cheap knock off from amazon for 20 quid (03L906051B) which is slightly different as the one on the car originally (04L906051B) and that was used on the left hand side, then I replaced the one on the right with the original I had just taken off. No idea if the slight difference means anything, though I am going to fit an OE part tomorrow at a cost of around £100. I have been looking for this information for a while now, great post, can you please clarify that you can put DPF cleaner down this o2 sensor hole thanks
