WRK Stewart Posted December 5, 2023 Posted December 5, 2023 Hi all I have a 2016 Q5 and the air blowing from the heater vents is not all that warm. Some vents blow warm and others are blowing cold. The car engine temp is 90 degrees c but the warm air is nothing special from heater. I flushed the heater core which has improved slightly but still not great. It’s a dual climate control system. Anyone run into this issue with Q5?
FunkySi Posted August 25 Posted August 25 Hi - I have the exact same issue with my 2016 Q5. the system has been bled without any change to the heating. Were you able to find the issue to your heating problem? thanks!
Steve Q Posted August 27 Posted August 27 Have you had a diagnostic check to see if any fault codes flag up?
Haines17 Posted Monday at 12:56 PM Posted Monday at 12:56 PM ive got this same issue, which i knew about when purchasing my q5, think its a fairly straight forward fix and either recirculation or flap motor which are both seemingly common to fail, I think passengers is easily got at from underneath glovebox drivers is from the side above break pedal? I think, ive gotta go out when it stops raining and take a cover off or so and check 🙂 i'd love someone to correct me so i dont have to remove the wrong covers lol
Steve Q Posted Monday at 01:02 PM Posted Monday at 01:02 PM 6 minutes ago, Haines17 said: ive got this same issue, which i knew about when purchasing my q5, think its a fairly straight forward fix and either recirculation or flap motor which are both seemingly common to fail, I think passengers is easily got at from underneath glovebox drivers is from the side above break pedal? I think, ive gotta go out when it stops raining and take a cover off or so and check 🙂 i'd love someone to correct me so i dont have to remove the wrong covers lol Great bit of information there. Sorry I can't answer your question though
