Andrew_Victoria Posted December 6, 2023 Posted December 6, 2023 (edited) Our car is an Audi A4 B7 3.0TDI quattro 2006 We took her out on Saturday night and drove to the shops 1 mile away. It was cold but she started no problem at home. When we stopped at the shops she failed to fire up. Turns over fine but no firing. Left over night until next day when warmer. Still the same issue. RAC called and he tried Easy Start. Nothing. Fault code on OBS reader is 00833 which shows Camshaft position error. I have ordered a new sensor which I will fit on Friday. Has anyone else experienced this issue with theirs? There is also an amount off soot on top of the engine which could be from EGR. I*t looks like this has been building up over time but she's never not started. Its a bit of a worry! any comments would be helpful to either ease the worry or point me in another direction. Thanks Just for confirmation. I believe there is only one Camshaft Position Sensor on Bank 1. Can anyone confirm or provide an image of location? Thanks Edited December 6, 2023 by Andrew_Victoria
Steve Q Posted December 9, 2023 Posted December 9, 2023 Does the car regularly do short journeys? As that could be causing issues with the dpf. I appreciate in this case it's the cam sensor though.
Andrew_Victoria Posted December 11, 2023 Author Posted December 11, 2023 Hi Steve, She was running short journeys up until 7 weeks ago (15mins each way to work). Now in working 30mins away from home each day mostly down the dual carriage way so she is getting some heat. I'm not sure on the DPF as its been re-mapped prior to my purchase. All I know is its stage 1 but don't know on DPF etc I changed the camshaft sensor on Friday and its still throwing the same 00833 code.
Andrew_Victoria Posted December 19, 2023 Author Posted December 19, 2023 After extensive calls and looking I feel the timing may have jumped a tooth on the Chain. Is Anyone interested in purchasing for spares or repairs. Interior is in excellent condition. All electrics work. Wheels and tyres all good. Darkside Developments FMI and hard pipes. Powerflow exhaust system with rear box delete on both sides. Pipercross washable filter. Was running stage 1. Just fitted new serpentine belt and water pump. Bodywork all in good condition. Its such a shame but i dont have the money to fix her. Let me know before i look to send her for scrap. Id rather she was put to use by someone who needs bit here first Sensible offers considered Thanks
Andrew_Victoria Posted January 1, 2024 Author Posted January 1, 2024 Not for sale anymore. can anyone help in locating the crankshaft sensor on my ASB 3.0 TDI engine. Thanks
56Doc Posted January 1, 2024 Posted January 1, 2024 I’ve used the ‘LLLPARTS’ website to help locate stuff before, it’s free to use. but it sounds like your cam chains have stretched. ( had mine done in Nov, tensioners we’re on their limit, so I caught mine in time.now have a dash like Xmas tree, so waiting for everyone to go back to work tomorrow to start calling) have you searched for Audi specialists in your area? & have you been able to confirm it’s the sensor not the chains? Think the engines back then had 4? But not sure.
Andrew_Victoria Posted January 1, 2024 Author Posted January 1, 2024 Thanks for your advice, I will have a look at LLLPARTS website. i had the engine running on easy start yesterday. So going to try the crankshaft sensor first before any further dismantling. I do have soot from the EGR area so will check that after fitting the sensor when I find it! I’ve not confirmed it’s the sensor but have had some diagnostics done. P0341 error code.
56Doc Posted January 1, 2024 Posted January 1, 2024 I know the cam chains are a big job, Audi charge about £2500-£3k I believe. my engine (2015 3.0tdi) needed a lot of new oil seals to go with it too. Job took a garage 4 days (with snags though, should have been 3).
56Doc Posted January 2, 2024 Posted January 2, 2024 My car was showing same fault, reset, it would just come back after a short time, but was starting and running ok, it rattled on start now & then and occasionally under acceleration, advice I was given was that if it rattled on every start, then the chains/guides/tensioners etc all needed replacing soonest. not sure what other symptoms you might have, there’s a lot of sound insulation in the A6, so it’s difficult to hear the engine on start with the doors & windows shut. But either way, good luck. 1
