bretty Posted December 13, 2023 Posted December 13, 2023 Hi everybody i’m new to this forum i have a 2007 Audi TT, Number plate lights are staying on with out key in ignition, Rear lights are working apart from tail lights & also the lights on the clocks dash are not working, does anyone have any suggestions to what it could be?
Steve Q Posted December 18, 2023 Posted December 18, 2023 Have you got wet carpets? As ccm is under the carpet and can cause electrical issues once flooded. Could it be an issue with the headlight switch I wonder as I've heard they cause odd issues with lights when they fail. Have you had a diagnostic check to see if any fault codes flag up?
