LBaker85 Posted December 14, 2023 Posted December 14, 2023 Hello everyone, new to the forum. I have an audi S6 2013 and I am trying to change my lights from AFS Xenon to Non AFS Xenon and I think there must be a change in the wiring loom pins? Reason being, I have bought some LED lights from China for Non AFS C7 (Yes I know, on both counts) - my car was with original AFS lights and there was a crack in both the glass frames so I was getting condensation in so I took a punt at trying to get Non AFS lights to work, to a certain extent I have been successful, I have coded the DRL and main beam lights to work using VCDS and removed error codes but the full beams are not working when trying to flash on the stalk etc.. So I am guessing the wiring is different on the wiring loom for Non AFS headlights for a C7. If anyone has a diagram of the wiring for Non AFS Xenon headlight connectors or a photo of their own I would be forever grateful. I am hoping I can just swap pins over to the correct place to enable the full beam press on the stalk to be sent to the headlights down the correct wire. Thank you in advance and let me know if you need any info but think I have covered it. Cheers!
