the tizer 1 Posted December 18, 2023 Posted December 18, 2023 (edited) My 2018 SQ5 low brake pad warning light and audible noise comes on after ignition is on, brake pads, discs and sensors changed but no help, no faults showing up when coder plugged in, any help/advice welcome. Edited December 18, 2023 by the tizer 1
Steve Q Posted December 18, 2023 Posted December 18, 2023 Could be an issue with the wire in the brake pad which lets the sensor know when the pad is low. Or the sensor or sensor wiring
Magnet Posted December 18, 2023 Posted December 18, 2023 Front or backs replaced Ian? Kind regards, Gareth.
the tizer 1 Posted December 19, 2023 Author Posted December 19, 2023 On 12/18/2023 at 10:20 PM, Magnet said: Front or backs replaced Ian? Kind regards, Gareth. Expand Hi Gareth The rear pads and discs replaced, the front has plenty of pads left on them, was told only two sensors fitted to this model O/S rear and N/S front, both sensors replaced
the tizer 1 Posted December 19, 2023 Author Posted December 19, 2023 On 12/18/2023 at 10:02 PM, Steve Q said: Could be an issue with the wire in the brake pad which lets the sensor know when the pad is low. Or the sensor or sensor wiring Expand Hi Steve both rear pads and discs replaced and O/S rear and N/S front sensors replaced, (was told that is the only sensors fitted to model) front brakes have plenty of pad left on them.
Magnet Posted December 19, 2023 Posted December 19, 2023 Many thanks Ian, A complete stab at it, but any chance this has something to do with having to computer reset? Kind regards, Gareth.
dalswinton Posted December 19, 2023 Posted December 19, 2023 Hi, It could be that the wire into the brake pad has become dislodged, I had the same problem a while ago. worth a look. Brian.
