superscub11 Posted December 27, 2023 Posted December 27, 2023 A6 c7 manual 2.0 tdi cglc not starting. Code p172300 Replaced clutch master cylinder thinking the switch was at fault... Issue still there. All related fuses and relays checked. Any thoughts?
evopilot Posted December 27, 2023 Posted December 27, 2023 do you get this error on the dashboard: "Engine start system fault. Please contact workshop"
Ssg Posted March 25, 2024 Posted March 25, 2024 On 12/27/2023 at 7:20 PM, evopilot said: Hi same issue with fault massage on dash "Engine start system fault. Please contact workshop" On 12/27/2023 at 7:04 PM, superscub11 said: A6 c7 manual 2.0 tdi cglc not starting. Code p172300 Replaced clutch master cylinder thinking the switch was at fault... Issue still there. All related fuses and relays checked. Any thoughts?
Ssg Posted March 25, 2024 Posted March 25, 2024 On 12/27/2023 at 7:20 PM, evopilot said: do you get this error on the dashboard: "Engine start system fault. Please contact workshop" ?
Ssg Posted March 25, 2024 Posted March 25, 2024 2 hours ago, Ssg said: Hi did you get to the bottom of that issue ?
cliffcoggin Posted July 9, 2024 Posted July 9, 2024 15 minutes ago, hotdog01 said: Hi did anyone solve this problem? Who can say? Superscub has not bothered to update us with the outcome despite last looking at the forum on 25th March.
