Maximum size of USB stick for music files
Go to solution Solved by Steview,
Hi,
Can anyone offer any advice as to the maximum size of usb stick that will work for music files, I have a Samsung 128gb Bar which works fine but when I tried to increase it to a 256gb Bar it keeps coming up with a message saying 'Files cannot be read from this device' I have tried it in all four usb slots in my car but no luck, I have also tried two other 256gb sticks but with the same result so am wondering if the maximum size is 128gb ?? (ps I know the sticks are fine because they work in my wife's Mercedes)
Thanks in advance
Steve
  • 7 months later...
  • Solution
I found a solution to this problem when the memory stick is formatted it defaults to FAT (Default) but when I formatted it to exFAT it works fine so hopefully if anyone else is having this problem then try this fix聽馃槉
There are file size and compatability limits to the various formats, which have caused me problems putting music on USB sticks. My main computer runs a Linux OS formatted to ext4, so I have to make a point of remembering to format USB sticks to either FAT32 or exFAT if I want to use them in the car.
