Headlight washers
Go to solution Solved by grim,
Hi all.
Question ?.
Headlight washer pipe has a leak at the the junction. It's a bumper off job to get to the coupling. If I pull the fuse for the Headlight washer pump will it continue to leak or am I gonna have to change the coupling.
Thanks Grant.
Hello Grant,
Not absolutely certain on this, but I believe the windscreen washers, and headlamp washers share the same fuse.
Hi Grant I believe Gareth is right. Also bare in mind if you have xenon headlights then the headlight washers are compulsory for the MOT.
  • 3 weeks later...
  • Solution
Posted (edited)
Hi. So pulled the fuse for the headlight washer and so far so good. But as it is a mot requirement will have to change the coupling behind the bumper at some point. 30a passenger side. window washer work as normal.
Edited by grim
