2019 A6 avant Front passenger sensor starting to beep when slowing down to around 10-15 mph. Normally the front doesn’t come on unless you push the button or select reverse gear and the drive forward. Any ideas?
Have you checked the sensor for dirt?
I'd also recommend a diagnostic check to see if any fault codes flag up
