DarrenJC Posted January 23, 2024 Posted January 23, 2024 (edited) Have the very common rear (inner) indicator failure message pop up over the last couple of days. probably due to moisture/all the rain we've had. Intermittent fault, works for 5 or 6 times after turning car on then fault pops up again. Weird thing is the hazards seem to work fine when I put those on. Have taken the light unit out and it was very wet around the gasket so I'm hoping a cheap fix will do it after a good dry and replacing the gasket. Failing that, I'll replace the unit but certainly won't be with a Valeo part £££ Gasket info below on Aliexpress for anyone who's looking for the same....if it works 🤣 Edited January 23, 2024 by DarrenJC 1
Steve Q Posted January 23, 2024 Posted January 23, 2024 2 hours ago, DarrenJC said: Have the very common rear (inner) indicator failure message pop up over the last couple of days. probably due to moisture/all the rain we've had. Intermittent fault, works for 5 or 6 times after turning car on then fault pops up again. Weird thing is the hazards seem to work fine when I put those on. Have taken the light unit out and it was very wet around the gasket so I'm hoping a cheap fix will do it after a good dry and replacing the gasket. Failing that, I'll replace the unit but certainly won't be with a Valeo part £££ Gasket info below on Aliexpress for anyone who's looking for the same....if it works 🤣 Keep us posted on how you get on. I believe the hazards run off a different system even though the same indicators flash. 2
DarrenJC Posted January 23, 2024 Author Posted January 23, 2024 2 hours ago, Steve Q said: Keep us posted on how you get on. I believe the hazards run off a different system even though the same indicators flash. Would make sense then Steve. Will pop an update in here when I try the gasket. Just to wait about 6 weeks on delivery off AliExpress 🤣 1
DarrenJC Posted February 14, 2024 Author Posted February 14, 2024 Update: this seems to have worked. Took the unit out gave it a good wipe down and dry, put the new gasket in and haven't had any issues since. I've washed the car too so power washer over that area hasnt led to any water ingress. A cheap and painless repair. If only they were all like that. 2
AlexD Posted Tuesday at 09:20 AM Posted Tuesday at 09:20 AM Hi, I have had a similar issue in the past resolved by drying up the light. It does not seem to work anymore and I am wondering if there is an issue with the wiring going to the rear left light. I want to plug in the left light into the right connector to see if the indictor would work and if it does confirm there is a wiring issue. Would there be any issues with trying that out ?
Magnet Posted Tuesday at 09:31 AM Posted Tuesday at 09:31 AM Do you have a multi meter to check bulbs, earths, continuity etc? If not, it’s worth buying one to move forward on this.
