Davegoorn Posted April 12 Author Posted April 12 Hello Gareth i have checked and double checked the wires gave each of thema good pull with the ignition on and in reverse hoping id see at least a flicker from the reversing light but nothing unfortunately doing the new plug repair has got rid of all the previous errors except the reversing light (see below) 2 Faults Found: 01134 - Alarm Horn (H12) 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 153 Mileage: 169737 km Time Indication: 0 Date: 2024.04.12 Time: 12:30:19 Freeze Frame: Term 15 On Voltage: 14.30 V ON ON Term 50 On OFF OFF 01518 - Bulb for Back-Up Lights; Left (M16) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 153 Mileage: 169737 km Time Indication: 0 Date: 2024.04.12 Time: 12:33:55 Freeze Frame: Term 15 On Voltage: 14.50 V ON ON Term 50 On OFF OFF I know the alarm horn issue wll fix that in due course as its the internal rechargeable batteries no longer holding a charge im at a complete loss now Gareth and hate to be beaten any ideas?
Davegoorn Posted April 12 Author Posted April 12 I dont have a multimeter as i have no idea how to use it im a mechanical engineer by trade, electrics are not my thing 16 hours ago, Magnet said: Hello David, This has been going on for some time, and without reading back over all the posts:- Have you checked the flexible harness section twixt tailgate and body - looking for fractured wires? Have you now got yourself a multi-meter? Kind regards, Gareth.
cliffcoggin Posted April 12 Posted April 12 Dave. Your error codes are still showing a short circuit or open circuit, just as they did two months ago when I suggested there was either water present or a broken connection. You will need to get a meter (and learn how to use it,) or take the car to somebody electrically proficient because tugging at the wires will not reveal the exact location of the fault.
Magnet Posted April 12 Posted April 12 Hello Dave, It just doesn’t compute with my logic, that you are attempting to sort out electrical issues, by simple ‘visual means’, when a basic multimeter would be the minimum requirement. Sorry to say it as it is, but you simply aren’t equipped - equipment or knowledge wise to solve this - if as you maintain that your mechanical engineering skills don’t flow over to any interest/knowledge of electrics, since they are ‘not my thing’. I think a lot of us on here have had to develop skills beyond our qualifications, or we make a decision to leave the solving process to ‘those who know’. I think this is really what you now need to do Dave - source the services of a trusted local auto electrician. Good luck and kind regards, Gareth.
Davegoorn Posted April 13 Author Posted April 13 just to let you know i now have a reversing light!!! Was a bad connection at the bulb holder for the reversing bulb a little bending of the metal strips and all good Many thx again for your help much appreciated 1
cliffcoggin Posted April 14 Posted April 14 Glad to read that. Common sense and a inquisitive mind can solve more problems than any amount of computer diagnoses. Regards, Cliff, a one time chemist with absolutely no electrical qualifications.
