Mrglee Posted February 17, 2024 Posted February 17, 2024 Car accelerates well until just over 3000 rpm then goes flat and get lots of grey smoke get code 00575 map sensor (this type inside ecu ) any usual suspect to check? or any other areas 96 1.9tdi afn
Mrglee Posted February 21, 2024 Author Posted February 21, 2024 Cheers Jason will check through that list engines done 185,000 oil is checked regularly since I've had it and toped up when needed was a little hesitant on full throttle when I got the car but got worse. Actuator works Vacuum pipes are original braided will change them all as most are fraying badly Turbo pipes are dripping with oil could be down to long term neglected cleaning but will check the turbo for wear.
Mrglee Posted February 25, 2024 Author Posted February 25, 2024 Can you confirm vacuum hose sizes is it 3.5mm 4mm and 5mm ID ?
Stevey Y Posted February 25, 2024 Posted February 25, 2024 On 2/21/2024 at 4:48 PM, Mrglee said: Cheers Jason will check through that list engines done 185,000 oil is checked regularly since I've had it and toped up when needed was a little hesitant on full throttle when I got the car but got worse. Actuator works Vacuum pipes are original braided will change them all as most are fraying badly Turbo pipes are dripping with oil could be down to long term neglected cleaning but will check the turbo for wear. Hi all classic signs of a split boost hose which allows to much pressure to be lost and fouls the MAP readings
Mrglee Posted February 28, 2024 Author Posted February 28, 2024 Cheers guys map is connected but have the type that's inside the ECU I haven't had a chance to look at much yet as my wife's daily drive and don't have a garage so work is dominated by weather I will get back to you all as I work through this and update. Can you confirm the smaller vac line sizes please as most of the cotton braiding has rotted off and may be causing the lines to collapse.
