A6 Avanti 2012 model
Go to solution Solved by SimonM,
Hi all, my A6 today, while driving with the cruise control active decided to cancel CC,  from this point I am unable to turn the cruise control back on !!
Any advice would be much appreciated.
cheers
Simon
Hi Jason thanks, I have no means of checking for codes !  I use the CC most of the time while on good main A roads and motorways etc.  the only other problem I’ve had a few day before is that I have an airbag warning light on, other than that the car drives well !
simon
Jason, a quick update CC working this morning !  The switch you mentioned is that the main one you use to turn CC off/on and set speed etc ?
Glad it's working again, id recommend a diagnostic check to see if any fault codes flag up
  • Solution
Hi Jason, I think you are spot on, as the switch did not have that nice click feel as you push it !  It’s been working great ever since.
Many thanks a great help.
simon
