aimzee Posted February 19, 2024 Posted February 19, 2024 Monday,19,February,2024,17:30:21:00009 VCDS Version: Release 21.3.0 (x64) Running on Windows 10 x64 www.Ross-Tech.com Address 02: Auto Trans Labels: 0AM-927-769.clb Control Module Part Number: 0AM 300 050 G HW: 0AM 927 769 D Component and/or Version: GSG DSG AG7 403 9030 Software Coding: 0000020 Work Shop Code: WSC 61255 001 1048576 VCID: 2D51BCB3B41137E358-8078 9 Faults Found: 006011 - Clutch 1 P177B - 007 - Tolerance Limit Reached - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 0 Fault Frequency: 53 Reset counter: 10 Mileage: 229779 km Time Indication: 0 Date: 2024.01.26 Time: 20:27:27 006012 - Clutch 2 P177C - 007 - Tolerance Limit Reached - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 0 Fault Frequency: 49 Reset counter: 10 Mileage: 229781 km Time Indication: 0 Date: 2024.01.26 Time: 20:30:35 006013 - Dual Clutch P177D - 000 - Torque too High - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 6 Reset counter: 10 Mileage: 230259 km Time Indication: 0 Date: 2024.02.16 Time: 16:11:58 006013 - Dual Clutch P177D - 002 - Torque too High - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 6 Reset counter: 10 Mileage: 230259 km Time Indication: 0 Date: 2024.02.16 Time: 16:11:58 001836 - Gear 1 P072C - 000 - Not Selectable - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 6 Reset counter: 10 Mileage: 230259 km Time Indication: 0 Date: 2024.02.16 Time: 16:11:58 001855 - Unable to Engage Gear 1 / Synchronization Gear 1 failed P073F - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 6 Reset counter: 10 Mileage: 230259 km Time Indication: 0 Date: 2024.02.16 Time: 16:11:58 006293 - Functional Restriction due to Pressure Drop P1895 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 6 Reset counter: 10 Mileage: 230259 km Time Indication: 0 Date: 2024.02.16 Time: 16:11:58 006293 - Functional Restriction due to Pressure Drop P1895 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 6 Reset counter: 10 Mileage: 230259 km Time Indication: 0 Date: 2024.02.16 Time: 16:11:58 001836 - Gear 1 P072C - 008 - Not Selectable - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 6 Reset counter: 10 Mileage: 230259 km Time Indication: 0 Date: 2024.02.16 Time: 16:11:58
aimzee Posted February 19, 2024 Author Posted February 19, 2024 Only when the car is warm it will clunk and not go into gear will this be the ecu on the gearbox
aimzee Posted February 19, 2024 Author Posted February 19, 2024 Does it sound like the mechatronics unit or the clutch has gone
aimzee Posted February 19, 2024 Author Posted February 19, 2024 That fault happened Friday Transmission fluid and filter was changed in January 2023
aimzee Posted February 19, 2024 Author Posted February 19, 2024 Ok do you think it could be the Mechatronics unit or clutch 🤔
aimzee Posted February 19, 2024 Author Posted February 19, 2024 There all the codes i got was what i put on here no warning lights just flashes on dashboard prnd and d2 no d1
aimzee Posted February 19, 2024 Author Posted February 19, 2024 It only drives when cold as soon as its warm it makes a loud bang noise like its stalled it only happend on Friday drove 30 minutes down road as soon as i come to a roundabout to slow down it went bang clunk like it stalled then no power turned off then on again had high revs straight into d2 then it died tried to restart car 4 times but it went bang/clunk into d2 but couldn't drive so got recovery home started it next morning absolutely fine but again as soon as its warm it starts doing the same thing i don't want to be charged for a mechatronics unit when it could be clutch rung 4 garages 3 out of four said mechatronics unit but can't get it in garage till the 1st for a proper diagnostic test
