Tam Posted February 21, 2024 Posted February 21, 2024 Can anyone tell me if there's a work around for removing the anti roll bar on a a3 8p 2010, Thanks.
Magnet Posted February 21, 2024 Posted February 21, 2024 Why would you want to do that Thomas? Kind regards, Gareth.
Tam Posted February 21, 2024 Author Posted February 21, 2024 It's bent, having problems with the arb rubbing the drive shaft on full lock, slid on ice a while ago and it's the last thing to fix, just don't fancy dropping the sub frame if l don't need to, cheers.
Magnet Posted February 22, 2024 Posted February 22, 2024 Thanks Jason, Ever tried to remove the saddle clamp bolts a 14 year old one of these on your back? Kind regards, Gareth.
Magnet Posted February 22, 2024 Posted February 22, 2024 Fair do s as we say in these parts - pretty good then - and Thomas knows where to come then. Kind regards, Gareth.
Tam Posted February 23, 2024 Author Posted February 23, 2024 Thanks for replies,much appreciated. just to clarify, l want to remove a damaged sway bar not the drop link and need to know if the only way to get this done is to drop the subframe or can it be removed any other way, Cheers.
