Walkie94 Posted February 24, 2024 Posted February 24, 2024 Hello, I have got a 2.0tdi s line 2008 on 104k There is a white smoke issue from my exhaust quite abit.. No loss of coolant No milky substance in the oil When starting the car it’s having rough idle almost like juddering, needle is not jumping though it stays at 900-1k a lot of white smoke from the back and smells of fuel It’s just had a dpf and egr delete i know the car will smoke abit anyway but this is an excessive Amount when on idle for longer then 10 mins Car has been plugged in and the injectors were reading 2.14 1.89 -167 -0.89 The only fault that come up was one of the injectors thrown a code up can’t remember what the number was If anyone can think what the issues could be or could tell me if it would be because of the injectors Help appreciated.
Walkie94 Posted February 25, 2024 Author Posted February 25, 2024 Not sure on the waste gate Car turns off after taking maf out both been coded out was slight smoke before hand but the dpf would have been hiding a lot of it still smokes this much after reaching temp no loss of coolant either IMG_6266.MOV
