David x Moore Posted February 25, 2024 Posted February 25, 2024 2003 A3 Sport - 5 speed manual Hi, lost the ability to get reverse gear any more. Inside the car, I can move the gear leaver as if I'm selecting reverse which although slack seems to follow the right moves, but I get a forward gear. It feels as if the linkage has changed in some way rather than a gearbox issue. I'd really appreciate some pointers about what to go look for. Thanks very much. Regards Dave
cliffcoggin Posted February 25, 2024 Posted February 25, 2024 I'd agree it is a fault in the linkage rather than the gearbox. The cable adjustment may have loosened at the gearbox end, or the cable mounting bracket may be loose. You will need to examine the whole linkage to find where the slack is. I have not done the job myself but the Haynes manual suggests a complicated juggling of springs and locking collars to detach the cables.
David x Moore Posted February 25, 2024 Author Posted February 25, 2024 Thanks very much. Will there definitely be cables in there, as all I can see at the moment is metal rods?
cliffcoggin Posted February 25, 2024 Posted February 25, 2024 They are Bowden cables: thick slightly flexible rods.
David x Moore Posted February 26, 2024 Author Posted February 26, 2024 Thanks very much Jasonj, I had found this video before, but it's not the same as my set up. I've had another look today in good light and think I've found the problem. One of the mini track rods has worn out and popped off it's peg. Just got to find new part now. Thanks. 1
