CT80 Posted February 25, 2024 Posted February 25, 2024 Hi anybody ever had the vechile start system failure please contact workshop?
Stevey Y Posted February 25, 2024 Posted February 25, 2024 1 hour ago, CT80 said: Hi anybody ever had the vechile start system failure please contact workshop? Hi most likely culprit is the clutch master cylinder this has a clutch position sensor on top of it and is part of the master cylinder, as the cylinder wears it measures the amount of fluid going past it and if its not within range it plays up, best policy is get the car scanned and see which faults come up.
CT80 Posted February 25, 2024 Author Posted February 25, 2024 14 minutes ago, Stevey Y said: Hi most likely culprit is the clutch master cylinder this has a clutch position sensor on top of it and is part of the master cylinder, as the cylinder wears it measures the amount of fluid going past it and if its not within range it plays up, best policy is get the car scanned and see which faults come up. Thank you, hubby went to turn car over yesterday, was struggling then all of a sudden the engine set on fire
Stevey Y Posted February 25, 2024 Posted February 25, 2024 1 minute ago, CT80 said: Thank you, hubby went to turn car over yesterday, was struggling then all of a sudden the engine set on fire Hi hope he is OK not nice but my guess is its the cylinder let go and squirted brake fluid on to something hot or electrical live, brake fluid only has a flash point of 7c.
