peter mouat Posted February 26, 2024 Posted February 26, 2024 Hi there, i am new to this website, briefly i purchased audi q7 gen 1. had it two weeks and already had water damage in the ECU. expensive fix …! i also have been having a problem with the headlights, i have ‘ dipped headlight fault showing on the dash ? i have replaced the bulbs, and also run a diagnostic on it, cleared the codes, but still showing up fault with dipped headlights.. can anyone help please. many thanks
Steve Q Posted February 26, 2024 Posted February 26, 2024 If you bought it from a dealer within the last 30 days then it is the dealers responsibility to repair the vehicle FOC or give you a full refund. If the ECU or ccm are water damaged then I suspect this will be the cause.
