stubby205 Posted February 28, 2024 Posted February 28, 2024 I hope someone can help. The engine light has come on, I've connected a friend's obd and there's two errors, both are p0131 "02 sensor circuit low voltage bank1 sensor1" does this mean I need a new lambda sensor?? Thanks in advance. John
Stevey Y Posted February 28, 2024 Posted February 28, 2024 56 minutes ago, stubby205 said: I hope someone can help. The engine light has come on, I've connected a friend's obd and there's two errors, both are p0131 "02 sensor circuit low voltage bank1 sensor1" does this mean I need a new lambda sensor?? Thanks in advance. John Hi yes normally O2 sensors need changing every 80k or five years if yours is the original I think you can safely say its had its fun. Steve. 1
stubby205 Posted February 28, 2024 Author Posted February 28, 2024 1 minute ago, jasonj said: Hi John , That's the one or you can remove and clean the one that's in Jasonj Thanks, I didn't realise cleaning them was an option. I'll look into this before I buy a new one.
stubby205 Posted February 28, 2024 Author Posted February 28, 2024 12 minutes ago, jasonj said: Hi John , GFS car parts £20 Type in your registration number engine size etc https://www.gsfcarparts.com/ Jasonj I'm not sure what I've done wrong here, £124 https://www.gsfcarparts.com/parts/electrical-lighting/sensors/lambda-sensor. thanks for the help though.
stubby205 Posted February 28, 2024 Author Posted February 28, 2024 It's 2007 2.0 tdi 170hp or the reg is lc57 vlx
