DeanBaker Posted March 6, 2024 Posted March 6, 2024 Does anyone know where to check for the latest software version numbers? I want to make sure my Q4 is as up to date as possible. I know my maps are up to date as I did them this morning but the software updates says to plug in a USB and it will check the USB and "online" for updates. I don't have a USB with any updates on it and when I pressed "check for updates" it said none were available. I'm not sure if it actually checked online and just failed / finished because a USB was not present. Is there a website where the latest MMI / software version numbers are published?
Stevey Y Posted March 6, 2024 Posted March 6, 2024 8 hours ago, DeanBaker said: Does anyone know where to check for the latest software version numbers? I want to make sure my Q4 is as up to date as possible. I know my maps are up to date as I did them this morning but the software updates says to plug in a USB and it will check the USB and "online" for updates. I don't have a USB with any updates on it and when I pressed "check for updates" it said none were available. I'm not sure if it actually checked online and just failed / finished because a USB was not present. Is there a website where the latest MMI / software version numbers are published? Hi I very much doubt there will be any updates for your car for at least another eighteen months as they only write updates and issue them to rectify oncoming problems over time and milage.
DeanBaker Posted March 8, 2024 Author Posted March 8, 2024 Thanks for the info, its most appreciated.
