DeanBaker Posted March 6, 2024 Posted March 6, 2024 I have just purchased a Blackvue Dr970X-1CH dash cam and will be hard wiring it this weekend. The hardwiring kit allows it to be wired to a permanent and ignition power source. I will be suing the parking mode feature so require the permanent connection. Has anyone else wired in a similar dash cam and if so what fuses did you use? I've looked at the fuse box in the glove box and matched it up to https://fuse-box.info/audi/audi-q4-e-tron-2022-2023-fuses-and-relays. The 12V is fuse F52 and I'm guessing its on an ignition power source. FYI I have a 2024 Q4 Sportback
