Ciaranmcm Posted March 6, 2024 Posted March 6, 2024 Just had my Q8 two months ago after having a Jaguar IPace. I was getting between 210-235 average miles with the IPace so when I ordered my Q8 etron 55 with the battery that was 20% bigger than the IPace I was expecting range of 250 miles +. So I’m now 2.5k miles in with an average 1.8m per kWh which is a range of sub 190miles to say I’m disappointed is an understatement. I contacted the garage and they advised that they have tested equivalent concerns to no avail 🤦♂️ if you want even average range EV avoid the Q8 it’s absolutely rubbish.
Anton8 Posted March 9, 2024 Posted March 9, 2024 Good Morning. Your range does seem rather low. The car weighs in at 2500kgs and with a 95kw battery I would expect more. My Etron GT has a 93kw battery and weighing 2300kgs I get a range of about 240-250. Not the 305 they advertise. 1
JMKC82 Posted March 9, 2024 Posted March 9, 2024 Hi Ciaran, Unfortunately it is not just about battery capacity. As mentioned by Tony, you also need to account for weight and aerodynamics, etc. With a slight added weight, and less aerodynamics, maybe bigger tyres so higher rolling resistance, etc, could all contribute to lower MPKWH. Any added electrics as well like a cool box, heated seated, etc? Also, the weather has been a little colder recently, so have you had the heating on more? I just don't want you to think about comparing apples with apples. Finally, i do have to say 1.8 MPKWH is quite low. Thanks, Joe
Anton8 Posted March 10, 2024 Posted March 10, 2024 Hi Ciaran I have never really checked the MPKWH on my GT by you have got me interested now. I have had the car since June 2023 and have covered 2292 miles. The long term memory tells me that the that the MPKWH is 2.2 miles. I mostly only make short journeys. Joe is quite correct in saying temperature, aerodynamics come into play. The GT is quite a slippery shape which all helps. Tony
