7-up Posted March 7, 2024 Posted March 7, 2024 I've seen earlier advice here on line about reseting the engines ECU because its built into the circuits for the cars immobiliser and if you are unlucky - you may have to reset it. Advice went on the lines of to reset the cars ECM/ECU. Turn your key to the accessory position (ACC). Disconnect the battery POSITIVE terminal. Wait about 1 minute, Tap the positive terminal 3 times and then reconnect to the terminal. The ECU/ECM is now reset. I'd be grateful to know if anyone has found this works , or used instead another idea, or successfully sent the car to an Audi Agent etc for a fix. I'm trying a few options but would like a bit more certainty. Best Regards
7-up Posted March 8, 2024 Author Posted March 8, 2024 Thanks for the reply.. Ive passed your comments to an electronics expert I know. The car, you may know has the earlier version of the OBD port, and only 2 pins. I've noted some audi's have a port on the ecu that services diagnostics. There is no port on my ecu but I do wonder if the way it's set up originnally is to use one of the 4 grouped connections, which in effect doubles as a diagnostic port. The car runs with the current ecu.. No mechanical issues. Don't be misled by the 2.8, v6, that uses a very different Maf and ecu set up. My main tack will be to clone the new ecu with the old one, just looking for ways, or companies to do this.
