jon sparham Posted March 11, 2024 Posted March 11, 2024 I have fault code P0183 fuel temp sensor. Does any body know where it is located on an A3 8p. Thanks
Stevey Y Posted March 11, 2024 Posted March 11, 2024 3 hours ago, jon sparham said: I have fault code P0183 fuel temp sensor. Does any body know where it is located on an A3 8p. Thanks Hi its usually on the fuel return pipe from the fuel rail. Steve.
cliffcoggin Posted March 11, 2024 Posted March 11, 2024 I did not know a fuel temperature sensor existed on A3s. What is its purpose? I could understand diesel temperature being important in cold climates because diesel can throw a waxy sediment when it gets cold, but surely not in Newquay?
Stevey Y Posted March 12, 2024 Posted March 12, 2024 21 hours ago, cliffcoggin said: I did not know a fuel temperature sensor existed on A3s. What is its purpose? I could understand diesel temperature being important in cold climates because diesel can throw a waxy sediment when it gets cold, but surely not in Newquay? Hi Cliff they are on all later cars as the sensor lets the ECU know the temp of the returning fuel from the rail, this is because part of the returning fuel is used to supplement the level in the filter housing when the car is under heavy load, most of the fault codes that are thrown up by this sensor are either due to bad wiring or most likely air bubbles in the return where it can't read warm air. Steve.
