Ricky Moxon Posted March 16, 2024 Posted March 16, 2024 Hi, the brake pad warning light came on today even though the sensor wires were cut and twisted together. I have now cut the plug off the ends off the loom and twisted the wires together to no avail. Can the sensor loom be turned off with vagcom if I take it to a garage. Cheers
Steve Q Posted March 16, 2024 Posted March 16, 2024 I think you'll have to solder them to make a circuit. You can't disable it via vcds etc. This video might help:
Ricky Moxon Posted March 16, 2024 Author Posted March 16, 2024 Cheers I have tried this already. The break must be further up the loom.
Stevey Y Posted March 16, 2024 Posted March 16, 2024 3 hours ago, Ricky Moxon said: Cheers I have tried this already. The break must be further up the loom. Hi you did not mention if its back or front, my guess is rear as the cables tend to deteriorate behind the arch liner where the loom travels through the body work, joining them wont help as one is live and the other isa voltage pick up. Steve.
Ricky Moxon Posted March 16, 2024 Author Posted March 16, 2024 I have checked the front. At a glance I could not see any on the back. I could only see abs sensor. I will re check tomorrow. Cheers.
