stubby205 Posted March 19, 2024 Posted March 19, 2024 I've owned the car for a few weeks now and I've just noticed the coolant is below the minimum level, it's pink but clear, the car doesn't over heat as I drove home after buying it for over an hour and there were no issues. Can I add coolant to what's already in it or should I avoid mixing coolants and flush it out and refill.
Steve Q Posted March 19, 2024 Posted March 19, 2024 As you've had it a week and if bought from a dealer then I'd recommend getting it back to them asap. As you are entitled to a full refund or for them to repair the vehicle FOC in the first 30 days of purchase. 1
stubby205 Posted March 19, 2024 Author Posted March 19, 2024 Unfortunately it was a private sale, there haven't been any other problems yet, and it's not causing an issue as I'm using it every day. I'll keep an eye on it and try to see if there's any leaks.
Steve Q Posted March 22, 2024 Posted March 22, 2024 On 3/19/2024 at 7:44 PM, stubby205 said: Unfortunately it was a private sale, there haven't been any other problems yet, and it's not causing an issue as I'm using it every day. I'll keep an eye on it and try to see if there's any leaks. Fingers crossed 🤞
Magnet Posted March 22, 2024 Posted March 22, 2024 Hello John, To answer your question on topping up, you need to buy a small quantity of pink OAT (concentrated) coolant and mix it 50/50 with water, and use this to top up when cold. If you are uncertain, you will not do any harm topping up with water, until you establish where the leak is - and it’s important that you find that leak site. Perhaps you could let us know how you get on John. Kind regards, Gareth. 1
stubby205 Posted March 22, 2024 Author Posted March 22, 2024 I will do thanks, I just need to find time to get in there and see if and where its leaking from. Thanks for the replys and I'll get it topped up ASAP 👍
stubby205 Posted March 22, 2024 Author Posted March 22, 2024 15 minutes ago, Magnet said: Hello John, To answer your question on topping up, you need to buy a small quantity of pink OAT (concentrated) coolant and mix it 50/50 with water, and use this to top up when cold. If you are uncertain, you will not do any harm topping up with water, until you establish where the leak is - and it’s important that you find that leak site. Perhaps you could let us know how you get on John. Kind regards, Gareth.
Magnet Posted March 22, 2024 Posted March 22, 2024 Don’t run this car with a low coolant level John. Recipe for disaster.
stubby205 Posted March 22, 2024 Author Posted March 22, 2024 Thankyou I appreciate it, i will fill it today. I did get some pink coolant, oat but then I read it needs to be g12 and it doesn't say g12 on it so I assumed I'd got the wrong stuff. I haven't returned it yet, would this be ok to top it up? 4 minutes ago, Magnet said: Don’t run this car with a low coolant level John. Recipe for disaster.
Magnet Posted March 22, 2024 Posted March 22, 2024 Don’t know John, so why not top it up with water until you find the leak source. 1
