My 2013 Audi A3 is misfiring. Taken it to the mechanic but they don't seem to know what the issue is. initial diagnosis shows an issue with Cylinder 2.
On ideal it is seems ok. when starting to accelerate, it runs rough and starts to backfire. This problem  doesn't occur when vehicle is warm but happens when cold.
Here are the current repairs that have been done but still no results
Parts changed
Intake manifold
high pressure fuel injector
Camshaft Adjuster Magnet
Gasket
Low pressure fuel injector
spark plugs
ignition coil
throttle body
ECU
Has anyone experenced this issue ,  what steps did you take to fix them ?.
Parts changed
Intake manifold
Gasket
spark plugs
ignition coil
throttle body
ECU
Hi have they scanned the car for fault codes, if so what were they, confused by the list, high pressure and low pressure injectors not heard of them.
