I have the following issue with my Audi A4 B8.5 2012 2.0 TDI Quattro 177 HP :
 "Steering Lock : Contact Workshop" It randomly appeared on the dash after washing the car, it stayed on for a day, then dissapeared for more than a month , now it came back again with more serious problems being:
When I put the key in the slot , I push it with my foot being off the clutch , the car gives "Steering Lock : Contact Workshop" fault. If I press the clutch and push the key once more, the car does not even want to crank, just takes off the ignition. If I push the key in several times, sometimes after 10-15 tries the car randomly starts, but still leaving the  "Steering Lock : Contact Workshop" fault on the dash.
The Start - Stop System works fine, if the system stops the car at a red light, when I put my foot on the clutch it starts the engine without any problems.
I found out, that my car has a battery installed, which is not for cars with start - stop system. I also learned that on the minus side it has a sensor, which could be faulty because of this battery? Does it worth changing it , or trying to change it?
VCDS software showed a malfunction at terminal 15 , "something something short to minus (or plus)". Unfortunately I don't have an OBD scanner, neither the VCDS software, so I don't have the scan, also I don't exactly remember the fault it showed on the scan.
I don't want to take it to a mechanic , because I fear that it will be really expensive, since they did not even know what the issue was.
Does anyone has an idea what could cause this type of fault?
Thanks David,
Have I got it wrong, but did you post a similar thread recently?
I did, however in this post is the full problem written down.
Posted (edited)
Fault code from VCDS software:
Access/Start Auth - Enabling Terminal 15 - 03026
Any ideas what this code means? Have anyone had this problem?
Quote
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 BG HW: 8K0 907 064 AG
Component: BCM2 1.1 H71 0252
Revision: 00002001
Coding: 0D0100
Shop #: WSC 02399 823 56573
VCID: 76E350D9C1C73AFAF7-8022
Subsystem 1 - Part No SW: 8T0 959 754 G HW: 8T0 959 754 G
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000030135007
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Serial number: 0208000000699002
1 Fault Found:
03026 - Enabling Terminal 15:
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 248
Mileage: 190015 km
Time Indication: 0
Date: 2024.04.03
Time: 13:28:03
Edited by David021
