jjb0800 Posted March 28, 2024 Posted March 28, 2024 Hello guys Just a quick question regarding the coolant on my car. I usually have to top up my coolant from minimum mark to max every 535 miles. Is this normal for consumption for this engine? I heard that it's slightly more than this but can anyone shed some light?
Magnet Posted March 28, 2024 Posted March 28, 2024 Hello Jubel, I would say any such coolant consumption - irrespective of model or engine - is abnormal. Our humble 174K A3 barely needs anything between it now 6K/year use. There is either an external leak, or it is being combusted. Have you carried out:- Inspection for any visible external leakage? Run the car for about 10 miles, park, get an assistant to rev. the engine to a steady 2000 rpm and hold it there for 2mins. while you observe the colour of the exhaust gasses? Kind regards, Gareth.
jjb0800 Posted March 28, 2024 Author Posted March 28, 2024 Thanks for your reply I will carry out the above steps mentioned and come back with findings. My A7 has done only 75k which is alarming 🥵
Guest Posted March 29, 2024 Posted March 29, 2024 Mine started doing this before Christmas and eventually lost power and overheated. It turned out to be the coolant pump and the coolant regulator valve. if you look down at the engine tray from the front near the radiator does it look damp? The coolant pump is to the lower right, is it dripping?
jjb0800 Posted March 30, 2024 Author Posted March 30, 2024 Hi Tommy, I don't see any dampness or dripping near the radiator and on driveway. I think it could potentially be leaking from thermostat housing or coolant control valve.
Magnet Posted March 30, 2024 Posted March 30, 2024 Hello Jubel, It could be potentially leaking externally from many areas, so really that just amounts to a guess. If it is due to an external leak then there is a high possibility that there will be visible evidence of this ( if accessible to the eye). No drips doesn’t necessarily mean no leaks, as the pressure will reduce as the engine cools. If this were mine, I would be carrying out the test I suggested, and if all is well there ( or particularly if not) get it thoroughly inspected and tested by a trusted independent. Kind regards, Gareth.
jjb0800 Posted May 20, 2024 Author Posted May 20, 2024 (edited) Hello guys, I ended up taking it to my local garage for diagnosis and unfortunately there was a massive coolant leak clearly visible when the car was up on the ramp. It was a big job, they had to take remove the front bumper and strip the engine to get to the V and the main culprit was indeed the coolant control valve. I had to also replace the egr valve, water pump with all gaskets,o rings and replace the oil and coolant, and oil cooler gasket all audi genuine parts from TPS total came to £1200 including labour. Common issue across the 3.0 tdi engines including the q ranges. BTW, having using v power diesel for over 20k miles my old 75k egr valve was spotless. Edited May 20, 2024 by jjb0800
Guest Posted May 20, 2024 Posted May 20, 2024 This is what happened to me give or take, I think you did ok for £1200, which was around what I paid. Interesting about the clean EGR valve, I only use BP standard so hopefully, mine won't be too bad.
jjb0800 Posted May 20, 2024 Author Posted May 20, 2024 Yes I also found it interesting, that's the first thing I asked to my mechanic who was doing the job. Shell Vpower does say what it says on the tin.
