Mark Viney Posted April 3, 2024 Posted April 3, 2024 Hi, I have a 2010 Audi a5 3.0 dci Quattro convertible, for the last 3 months the soft top has not worked. Later the boot was not working so I had to use the key to open it. Today the soft top started to work, although I haven’t done anything,and also the boot opened as normal. Can anyone explain what has happened. I know I’ve had problems with the electric seats due to water entering the floor area. Which as far as I know has been resolved by the mechanics although he says he is sure there is still water under the floor. I believe there may be a connection between the soft top and the boot lock, does anyone think it may be e relay connection ,or something else. Any help would be appreciated, regards, Mark
Steve Q Posted April 4, 2024 Posted April 4, 2024 If there's still water under the carpets then this could be damaging the comfort control module. I'd recommend a diagnostic check to see if any fault codes flag up
