Moses Posted April 4, 2024 Posted April 4, 2024 Hi All I have an Audi A4 2016 Model, today whilst driving the MMI switched off. I switched it back on and all is working except the 'CAR' page, where you view your oil, service etc. Message reads: The car system settings are unavailable (see pic) Any advise? Thanks in advance.
Steve Q Posted April 4, 2024 Posted April 4, 2024 Id recommend a diagnostic check to see if any fault codes flag up. I'd suspect an issue with the mmi or with the sensors/wiring that runs from the engine/ECU to the mmi.
Moses Posted April 4, 2024 Author Posted April 4, 2024 41 minutes ago, Steve Q said: Id recommend a diagnostic check to see if any fault codes flag up. I'd suspect an issue with the mmi or with the sensors/wiring that runs from the engine/ECU to the mmi. Ok I guess an independent Audi garage can do this? Hopefully it ain’t too expensive
Steve Q Posted April 4, 2024 Posted April 4, 2024 14 minutes ago, Moses said: Ok I guess an independent Audi garage can do this? Hopefully it ain’t too expensive Yea an Audi independent is an option or an auto electrican 1
Moses Posted April 4, 2024 Author Posted April 4, 2024 2 hours ago, Steve Q said: Yea an Audi independent is an option or an auto electrican Any idea of costs?
Steve Q Posted April 4, 2024 Posted April 4, 2024 5 minutes ago, Moses said: Any idea of costs? Now that's a good question. I'd budget at least £160 for diagnostic worst case scenario. I'd it's mmi might be worth sourcing a second hand one that can then be coded to your car.
