mikeb3 Posted April 4, 2024 Posted April 4, 2024 (edited) Hi, I'm new here and could really do with some help. I have an Audi A4 B8 2.0 tdi 2009. The car started to blow out quite a bit white smoke from the exhaust about 3 days ago, it still seemed to run ok but the smoke has now seemed to have got a bit thicker and also a bit of engine shake on start up and sometimes a bit of a clicking noise when revving and also a bit of a misfire. There are no warning lights on the dash. I had the breakdown company out yesterday and he seemed to think it was a faulty injector. I also had a mechanic do a scan this morning and it came up with these results.... Cyl 1 Injection quality variation value (mg/stroke) -2.52 Cyl 2 Injection quality variation value (mg/stroke) 0.39 Cly 3 Injection quality variation value (mg/stroke) 1.09 Cyl 4 Injection quality variation value (mg/stroke) 1.01 So am i right in thinking that Cyl 1 injector is faulty as the mechanic didn't seem to know a lot about diesel injectors Any help would be appreciated Edited April 4, 2024 by mikeb3
David021 Posted April 14, 2024 Posted April 14, 2024 Yes. You have to change or refurbish the injectors. Had the same problem. I recommend that you change or refurbish all of the injectors, so you won't have any problems afterwards.
