Steve30 Posted April 15, 2024 Posted April 15, 2024 Hi, I've recently picked up a 2014 A7, I'm getting quite a bit of wind noise from the passenger window. I've investigated and the window doesn't quite go all the way up when you shut the door, probably about 2-3 mm short. Does anyone know of a way I can sort this out? Thank you in advance! Steve
Stevey Y Posted April 15, 2024 Posted April 15, 2024 1 hour ago, Steve30 said: Hi, I've recently picked up a 2014 A7, I'm getting quite a bit of wind noise from the passenger window. I've investigated and the window doesn't quite go all the way up when you shut the door, probably about 2-3 mm short. Does anyone know of a way I can sort this out? Thank you in advance! Steve Hi do the global opening and closing a couple of times on the key fob and that should re educate it. Steve.
Steve30 Posted April 15, 2024 Author Posted April 15, 2024 Cheers Steve, I'll give it a go in the morning! Steve
